Major Fuel Leak upon Engine Startup. Cant find leak.
Past few days my 3.4l Runner would idle rough upon cold startups. The truck has been seafoamed, Throttlebody Cleaned Routinely so I figure it was not Carbon buildup or Air leak. I would then to smell fuel, I figure it was a bad injector etc.
One day after leaving work I started it up and it was Idling very irraditc, I went to go open the hood and before I even stepped out I saw a good amount of fuel pouring from the engine. I turned off the truck and inspected my lines.
From the Fuel Filter to the engine seems fine, No cracks or Leaks, and from the retur back to the tank there seems to be no Leaks in the metal lines going back.
On top of both exhaust manifolds seem to have fuel build up, and the fuel leaks down fromthe back of the engine down to the steering rack to the skid plate.
It is really hard to see where exactly the line is going that leaks but not visible right now. I seen a thread prior saying there is a line on thiem intake manifold but It was on a 91 Runner.
The injector rail on the passenger seemed dry and so did the line to it aswell.
Any suggestions/help is welcomed.
Could be o-ring on one of your fuel injectors is shredded. Hard to see unless you have someone in there looking while engine is running. Whatever you do do not, i repeat do not drive your truck. The exhaust crossover runs directly behind and below intake manifold and can get hot enough that it would be possible to ignite the fuel.
bigblue82
10
Jul 6, 2015 08:27 AM
shadowbirdie
Jun 24, 2015 03:54 PM
crazypaint
Jun 23, 2015 03:27 AM
newzingo
Jun 19, 2015 04:37 PM
