22 RE "91" 4 runner cold idle very high
Old Oct 28, 2011 | 08:53 AM
wyoguns's Avatar
Had a long block installed and now the cold idle is 2100rpm's.After warm up idles fine at 750-800 rpms.The garage said they made no adjustments.Any suggestions would be much appreciated.Checked for vac leaks and didn't find any.The last two long blocks did not have this issue.
Old Oct 28, 2011 | 09:52 AM
tj884Rdlx's Avatar
sounds like a defective long block then. hope you've got a warranty.
or, you could GO TO GOOGLE, TYPE IN "22RE COLD IDLE" AND READ EVERYTHING YOU SEE.
it will look like this:
22RE High Cold Idle - YotaTech Forums
www.yotatech.com › ... › 86-95 Trucks & 4RunnersCached - Similar
You +1'd this publicly. Undo
7 posts - 6 authors - Last post: Apr 10, 2006
Hey all, big fan of the site. Been having trouble lately with my truck's idle. On cold mornings idle is about 2000-2200rpm, even with cold start ...
22re high eratic idle when cold‎ - Feb 3, 2011
88 22re hard start, rough idle when cold....good after warms up ...‎ - May 4, 2010
22re Cold Idle Adjustment‎ - Mar 14, 2009
cold idle speed adjustment 22re‎ - Jan 6, 2006
More results from yotatech.com »
Get more discussion results
22re cold idle set up - Pirate4x4.Com Bulletin Board
www.pirate4x4.com › ... › Toyota - Truck and 4RunnerCached
4 posts - 4 authors - Last post: Jan 23, 2010
I have installed a 22re in my 82, starts and runs great, but there is no high idle when it is started and running cold, it runs ok but you can tell it is ...
85 22re idle surge and strange vacuum part id help‎ - 5 posts - Feb 25, 2010
'87 22R (carb) rough idle‎ - 13 posts - Jun 12, 2006
22RE cold idle speed adjustment‎ - 1 post - Jan 2, 2006
really really high cold idle??‎ - 18 posts - Feb 24, 2004
More results from pirate4x4.com »
22RE Idle Problem - IH8MUD Forum
forum.ih8mud.com › ... › 79-95 Toyota Truck TechCached - Similar
9 posts - 2 authors - Last post: Mar 8, 2008
I've got a 90 22RE 5-speed that doesn't want to idle when warm. It will start up when cold and idle fast until it's warm; but after a 45 min run ...
Surging Idle‎ - Dec 22, 2010
94 Pickup 22RE - Rough Idle starting cold for 15-20 seconds??‎ - Jan 11, 2008
22re really high cold idle‎ - Jun 18, 2006
22RE cold run = no idle‎ - May 2, 2006
More results from forum.ih8mud.com »
Low idle on cold start - '88 22re - Toyota 4Runner Forum
http://www.toyota-4runner.org/.../77...2re.htmlCached
2 posts - 2 authors - Last post: Dec 6, 2010
Thanks in advance for any help. I recently bought an '88 4runner 22re. Absolutely love it, but am having an issue with cold start.
GOOD LUCK, WE'RE ALL COUNTING ON YOU
Old Jan 3, 2013 | 09:07 AM
Chaviator's Avatar
My truck has low idle or no start at all...
My 88 toyota 4runner when it's cold, winter, or in the morning in summer, it either does not start (winter) and if starts (summer/winter) does not want to stay on. I have tested, checked and cleaned: air intake, cold start sensor, air control valve, the sensor located after the air filter, forgot the name...all according to results are good...I do not know what else to do. I have to stay in the truck for a few minutes, at least 5, in order for it to stay on, on its own, very low idle almost stalling. Once it's warmed up, it has a good idle. If turned off and then on within one minute while warm, cranks very low idle like I just cold started it and I have to accelerate it in order to get back to normal idle again... Do any of you guys have had a situation like this? I have read similar issues, checked and tested what was recommended and still have the problem. Thank you in advance. I hope I can get this nightmare out of my way soon. I have dealt with it for the last 4 years...
Team420
Jan 12, 2021 04:57 PM
Cesarl74
Apr 23, 2016 06:07 PM
Sandman
Jul 23, 2015 08:15 PM
Yota.Jay
Jul 2, 2015 12:57 PM
jmc88runner
Jun 18, 2015 03:39 PM
