4x4 ECM in a 2Wheel drive?
Old May 25, 2011 | 11:49 AM
T-Dubya's Avatar
I have a 2 wheel drive 93 4runner with a 3vze. I noticed the there was a trans code 65 which was odd because that code would be for a 4x4 trans. when I went to look at the ecm i noticed it was for a 3VZE A/T 4x4. I know the engine had been replaced by the PO. Does anybody know if this could be a problem? shift points etc. and how do i know which computer to replace it with, if needed. different engine and ECM.
Old May 25, 2011 | 12:40 PM
DeathCougar's Avatar
Wait....what?! 96 4Runner with a 3VZ? Did you swap in an older motor for some ungodly reason?
Old May 28, 2011 | 04:52 PM
T-Dubya's Avatar
Sorry, My bad. Its a 93, and I fixed the problem, found a 93 runner with a 3.0 2wd auto at pick and pull, and what do you know it still had the ECU, Switched them out and my slow idle went away, shifts better, no codes, and more power too.
Colington
Mar 8, 2020 09:51 AM
mskalmus
May 28, 2017 07:51 AM
Sep 4, 2015 09:27 AM
Poncho0206
Jul 10, 2015 06:21 PM
garagespace
Jul 9, 2015 08:37 AM
