Alternator serpentine belt problems (loud squeal)
Hey all. I've taken some time and searched all over the forums but haven't found my specific problem being discussed. Here's the SparkNotes version:
- 1992 4Runner V6 3.0 3VZ-E 4WD, 230k+
- Serpentine belt snapped
- Got a brand new one to replace it
- Reassembled everything and there is a loud-ass persistent squeal and burning rubber smell... definitely didn't run it long
- Trouble-shoot by only running one belt by itself, still comes down to the alternator serpentine
- Tried tightening the tension, tried loosening the tenion
- Tighter resulted in louder squeals and more smell; looser resulted in the belt not spinning at all and the crankshaft pulley just going freely (the belt was pretty loose, too, after several steps of looser and looser with the same squealy results)
- Alternator pulley spins very well with no belt on it
- Returned the belt and got replacement in hopes of it just being a faulty part
- Still squeals like a dying pig
- As some have mentioned in other related threads, it is definitely not a timing-belt/idler pulley issue. I've worked on that area extensively and it performs like new
My mechanical skills are at least good enough to replace a timing belt, water pump and starter but I'm absolutely stumped here.
Somebody please help!
sounds like the alt might have a bad bearings and when u put pressure on it they bind and casue it to squealing belt even tho u can move it freely when there is no belt. had a neon do this and had to rebuild the alt. or u might just not be getting the belt tight enough.
Check the fan pulley bracket. The bearing in that will wear out over time. Mine squealed off and on for awhile till it eventually gave out, seizing up and melting the power steering belt and alt belt. looks like http://www.toyotacatalog.net/M1WebGe...B-009B3C7FC3AA
The more I think about it the more I'm convinced it's the alt bearings as justin said.
So why not narrow it down some more and take the alternator in to get tested before replacing it? If it is the alternator, it should do the same when it is on the machine at the parts store and they will test it for free. Are you sure you are getting the belt lined up all the way? I am sure you have as you have taken it off a few times but if its not lined up on all the pulleys it will make noise and ruin the belt.
Is there any way to get in there or do I just need to buy a new bracket?
Wow don't I feel like a jackass. You were right.... and I just spent the last 30 minutes trying to take the pulley guide off with a pulley remover to access the bearings before I realized it can't be taken off!!
So all is well! I went to the Pick 'n Pull in town and got a bracket for $9.99 (man I love that place!) Works like a charm and I couldn't be happier with my old girl
Thank you all for your help. Yotatech is amazing!
dinks07
Jul 15, 2015 05:34 PM
