w50 and w56 same bellhousing?
hi guys new here, just wondering if the w50 and w56 gearboxes have the same bellhousing?
As well as an original '83 40series Landcruiser. i have a 2a landrover with a 245 hemi and have been offered an adaptor kit which was used with a 2wd valiant with a w50 gearbox. id obviously want 4wd and would therefore like to use a w56 as it will already have a transfercase.
so again to my question; do they have the same casing/bellhousing so i could use it?
cheers
Andrew
cheers
Andrew
The W50 was mostly used in 1976-1981 Celicas. It has a shorter bellhousing (face to transmission mount) than the later W56/W58 series transmissions did, despite using the same mounts. So my answer would be no.
FS[PacNorWest]: 1987 4Runner SAS, 22RE, 5Spd, Dual Cases, etc
toyotasaurus
Sep 24, 2015 03:30 PM
WTB[PacNorWest]: w56 c manual trans with t-case and drivelin
89hilux1
Jul 19, 2015 01:32 AM
2cyl, 4a, 4wd, adapter, bell, bellhousing, bellhousings, gearbox, housing, l52, toyota, transmission, w50, w56, w58
