need help with broken rear axle shaft
Old Apr 9, 2011 | 07:26 AM
cootees's Avatar
Broke a rear axle shaft right at the hub. I can't find any info on how to go about getting the rest of the shaft out while it is still locked in the diff.
Any suggestions?
Old Apr 9, 2011 | 07:44 AM
justin_4runner's Avatar
weld a bolt on the end of it and get a slide hammer and that should get it out, if no welder then u might be able to open the diff and see if u can get something in there to pry it out.
Old Apr 9, 2011 | 07:47 AM
cootees's Avatar
welder thats a good idea. Thanks. I'll give that a go.
Old Apr 9, 2011 | 09:30 AM
MudHippy's Avatar
The rear axleshafts aren't "locked in the diff". There's nothing holding them in except the wheel bearings, bearing retainers, and snap rings. Follow the procedure for removing the rear axleshaft and wheel bearing, the remainder of the axleshaft will slide right out still connected to it and the brake backing plate assembly. Piece o' cake!
http://personal.utulsa.edu/~nathan-b...33rearaxle.pdf
BTW, you can't "open the diff" without removing both axleshafts first either.
What would you people do without me?
Old Apr 9, 2011 | 09:59 AM
cootees's Avatar
I got it out. The problem was that the shaft was far enough in the axle tube that prevented me from possibly get a grip on it to pull it out.
Old Apr 9, 2011 | 10:05 AM
MudHippy's Avatar
Oh, so it broke behind the bearing. I was assuming it broke right behind the hub in front of the bearing. Though that would be ALOT less likely, due to it being thicker there.
Old Apr 9, 2011 | 05:23 PM
vital22re's Avatar
totally a bro
I think we need pictures of this carnage. How did you get it out?
Old Apr 13, 2011 | 04:45 AM
Kaptain's Avatar
They typically break behind the bearing.
To the OP - what were you doing when it snapped? The stock shafts are very stout and they take a lot of abuse.
Old Apr 13, 2011 | 05:04 AM
cootees's Avatar
it slid right out with ease once I could get a hold of it.
Thats the kicker. I have 37's but I was just cruising down the street doing about 50mph. Haven't even ever wheeled it with the 37's.
Old Apr 13, 2011 | 05:26 AM
skronzor's Avatar
Nice. You should post a picture. If you Can
Thanks
Old Apr 13, 2011 | 05:39 AM
xxxtreme22r's Avatar
hmmm broke a rear shaft on 37's before you broke a Birf? I don't believe it without
Old Apr 13, 2011 | 08:03 AM
Kaptain's Avatar
Interesting... Did you ever put new rear bearings in it? Did you use a torch to take off the old bearing and sleeve?
I suspect the extreme heat weakens the shaft and causes it to break in that spot.
Old Apr 13, 2011 | 10:01 AM
MudHippy's Avatar
Yeah, that's what I meant by that. But that's not exactly what he said happened.
Of course if it had snapped "right at the hub", that would've meant the wheel came of while he was driving 50 MPH. And he probably would have mentioned that fact.
88sasturbotoy
Jan 30, 2026 01:57 PM
A2theK
Jan 10, 2016 10:18 AM
jerusry
Oct 19, 2015 05:28 PM
deepmarsh
Aug 6, 2015 03:44 AM
toyoda8488
Jul 5, 2015 10:18 PM
