help ID'ing the last 3 plugs..
Old Apr 7, 2011 | 10:50 AM
Dento77's Avatar
i'd like to ask if i could get some help ID'ing these connectors. 3.4 donor is from a 99 4runner limited and these 3 are inside the cabin headed up towards the dash area.
i thought i downloaded everything i needed from TIS but i cannot find these 3 plugs anywhere in my info. even just the name for the plug would help. thanks ahead of time for any info.
Old Apr 7, 2011 | 01:47 PM
DWEINBERG01's Avatar
Small grey one is listed as II1. Small white one is II2 and the big one is II3.
I have what my stuff is listed as. If you need it shoot me a pm and I can email it to ya.
Old Apr 7, 2011 | 03:44 PM
Dento77's Avatar
pm sent.
thanks, any info is greatly appreciated. i'm usually pretty decent with EWDs, but toyota ones.. heh.. are not my friend.
Old Apr 26, 2011 | 10:15 PM
timmJ's Avatar
Well I may be screwed on my harness
Those look like the plugs I have been tracing to match up with my IH1 and IH2 body harness plugs in my '95 runner. So are these not the plugs you will use to "wire into" to complete the swap?? I have the three other plugs that go directly into the ECU and two of these II1 and II3 leftover and assumed these would be the ones for the real wiring swap effort. I can't find the IE1 and IE2 that everyone else seems to be using. My donor is a 97 4runner M/T 4wd. Do you guys know??
Old Apr 27, 2011 | 09:25 AM
hamish_18's Avatar
so 97 used the 2 row plugs. The other one you need for the ecu you pull from your original 3.0 harness. And you should only need the ii3 plug to use to splice into the ih1 and ih2, or c1 and c2 if you have a truck...
Old May 3, 2011 | 04:27 PM
Houston5's Avatar
Plug Id
Where are you guys finding the Ids for these plugs?I have also downloaded the EWD from TIS and can't seem to locate these three plugs as well.Mine happen to be for a 98 Taco(small blue,2 white).I also have a FSM for my 89 4runner and can't seem to locate the plugs there either.I just cant seem to find the (I)plugs.Maybe I am just not looking in the right place.I would like to have a diagram,drawing,pic something to id the ones from the body harness to make sure i have the right ones.From what i have gathered is that these three will be spliced into my body and the others into the engine harness correct?Any help would greatly be appreciated.
Old May 4, 2011 | 11:50 AM
hamish_18's Avatar
its right next to the plug. It will have a square box and the pin number. here I will post a pic to show you...
Old May 4, 2011 | 11:55 AM
hamish_18's Avatar
Red arrows are pointing to the plug names in this ewd..
Uploaded with ImageShack.us
Oh and that ewd was from a 98 taco. taco's are Ik1,2,3. not II1,2,3 like the 4runners..
matmattmatthew
10
Feb 9, 2021 04:15 PM
MichaelKLerner
Oct 27, 2015 07:18 PM
Longbed 90
Oct 19, 2015 11:05 AM
yota_in
Jun 27, 2005 04:49 PM
