4.3 swap with yota or gm t case?
Alright so i'm doing my 4.3 swap with a 700r4 tranny and was planning on using a np 208 t-case. Then i found the adapter to use the yota t-case for $250. The main reason i was going to use the gm t-case is to keep the cost down. Just wonder if using the yota case will save me money in the end? So what you do, yota or gm case?
Thanks, Doug
Thanks, Doug
I'm no GM expert, so I don't know what kind of tcase it was. But the '92 S-10 blazer that was my donor was Driver's side drop. So you'd need a different front axle.
I think that's the only challenge you might run into.
Here's a foum i started about using them, seem like its been done quite a bit.
https://www.yotatech.com/forums/f163...ng-one-216218/
crashburnoveride
Jul 10, 2015 06:39 AM
toyoda8488
Jul 5, 2015 10:18 PM
