Gears and lockers
Old Dec 16, 2003 | 08:30 PM
Maverick's Avatar
Gears and lockers
I have a 3 inch lift on my truck. It has a 22R 4-cylinder in it. I'm thinking about putting 4.88 gears in her and a detroit true trac any suggestions or comments. Will the locker help in snow and mudd in 2-wheel drive, and also with the gears make a big difference in high way performance and overall stop and go driving. Thanks in advance.
M
Old Dec 16, 2003 | 09:02 PM
doink's Avatar
what size tires are you gonna be running?
Old Dec 16, 2003 | 09:21 PM
toy283's Avatar
FWIW, a True Track is not a "locker" it is a "limited-slip". Being a limited slip, it will help in the snow and ice without any serious detrimental effects on dry pavement like a locker has. The 4.88 gears are gonna increase your engine speeds dramatically unless you install 32-33" tires to compensate.
Old Dec 18, 2003 | 10:26 AM
Maverick's Avatar
I'm going to be running 33x12.5 mud tred.
Old Dec 18, 2003 | 10:48 AM
rollandfayssoux's Avatar
running 488 gears and 33's will bring the drivetrain to a stock dinal drive ratio but running the 33's will definately decrease your mpg's because of the rolling resistance (friction) of the larger tires. if you want a locker you can go with a lock right, works good and is really cheap.
Old Dec 18, 2003 | 05:49 PM
Maverick's Avatar
I'm sure the mpg will be better with the 4.88 rather than stock gears with 33's, and the acceleration will increase too right? I don't know if I want a locker or not, I just want something that will help control the slip when I'm in the rain or comming up a hill on a gravel road etc.
M
oldirtydirt
Feb 23, 2020 09:30 AM
malteserunner
Early Land Cruisers (Build-Up Section)
89
Feb 9, 2018 06:59 AM
jerusry
Oct 19, 2015 05:28 PM
Daneums
Jul 28, 2015 11:57 AM
coffey50
Jul 28, 2015 10:55 AM
