Parts I should rob off an '85 Celica 22RE??
While at the boneyard today,I spied an '84-85 Celica w/a 22RE in it & everything underhood is still there!Seeing as how I'm new to the 22RE family..are there any parts I should rob for my '85 (22RE) 4x4, 5-speed pickup? I will be building a 22RE in the future(higher performance) & wonder if the cars had better intakes/throttle bodies/etc
. The airbox+elbow looked like a drop in to move the air inlet over to where the battery is now(pass. side) & get it OFF the radiator. Suggestions? Thanks,Sleepr71.
That is the same engine as in your truck.
There might be a few things that look different you might want the coil and igniter doesn`t hurt to have extra relays and such.
If your into doing neat wiring you might want to grab the engine harness and the euc.
Injectors and fuel rail.
Do you want an extra head?
I guess it depends on how much room you have to store things
If you have the space you will fill I have 8 or 9 Celicas
