MISC yota parts
Old Dec 29, 2010 | 06:32 AM
sgtbriangreen's Avatar
MISC yota parts
I will add and delete as I find stuff and sell stuff.
4cyl Tcase. Stock gears. Interlock pin has been removed. this case has the longer forward shift rails. Not for W56C or D transmissions. Transmission must have the 2 separate shifter bases for this tcase. $50
Homemade Ubolt flip plates. Same dimensions as the ones you can buy online without the angle on the front. These are flat 1/4 plate. For front axle or rear 1st and 2nd gen. Will not work on 3rd gen axles - they have wider spring perches. $20
Homemade Ubolt flip plates for 3rd gen rear axle. I had these made from 3/16 plate and they are wider than the ones you can buy to fit around the wider spring perches. $20
22RE intake manifold. Upper, Lower, Throttle Body, fuel rail, some vac lines, some VSVs. $40
Blower motor from an 87 runner. It works. $20
All prices are OBO and do not include shipping.
Old Dec 29, 2010 | 09:18 AM
Woods12's Avatar
How much would shipping be for the fender trim pieces to 35058.
Old Dec 29, 2010 | 01:20 PM
Shouldnt be too much. Maybe $10. Ill get a pic of them up in a little bit.
Old Dec 30, 2010 | 10:08 AM
Also have these revolver shakles for $30. Top bolt is 18mm (stock yota size) Bottom is setup for chevy springs. With these shakles, you wont have to move your rear shakle hanger.
Old Jan 2, 2011 | 05:38 PM
InvaderTrax's Avatar
Do you have bolts for the shackles? I really want them
Old Jan 3, 2011 | 01:29 PM
The top bolt is the same (18mm) that you can get for any of the shakles from marlin, all pro, trail-gear, etc. The bottom bolt is the OEM chevy 9/16 bolt. What is in the picture is all I have. I believe you can even use the stock toyota shakle in place of the included top shakle.
Old Jun 1, 2011 | 09:17 AM
jmitchell2008's Avatar
i was wondering if you had the skid plate and mounting bracket for the gas tank an 93 22re
Regency
20
Jan 3, 2020 07:43 PM
mdev126
Oct 4, 2015 04:48 AM
Sep 4, 2015 09:27 AM
msane99
Jul 17, 2015 10:13 AM
akaphilly
Jul 9, 2015 02:34 PM
