Hand turned compression test
Old Dec 2, 2010 | 04:30 PM
grimmsly's Avatar
I just got the timing chain on the sprocket and i was hand spinning the crank around to see how the compression is looking and these are my results:
1- 30psi
2- 60psi
3- 60psi
4- 30psi
Why are the 1st and 4th cylinders showing such a low reading? would bent valves cause that?
UPDATE:
I put air into the cylinders and the exhaust valves on cylinder 1 and 4 are leaking, what a shame, head is coming off now :/
Old Dec 2, 2010 | 04:57 PM
vital22re's Avatar
totally a bro
hand turned? search compression test and follow the proper procedure.
Old Dec 2, 2010 | 05:10 PM
sam333's Avatar
Old Dec 3, 2010 | 05:32 AM
Marc's Avatar
Originally Posted by grimmsly
UPDATE:
If the valves aren't closed they will leak.
Did you do the leak down on each cylinder when they were on the compression stroke?
Old Dec 3, 2010 | 08:10 AM
sam333's Avatar
your going to have some leakage even on a good head. Thats why you use a calibrated tester( leak down/) and specific methods for testing.
Sleaker
Aug 26, 2020 06:03 AM
the1998sr5
15
Jul 14, 2020 08:35 PM
jasonty
41
Dec 23, 2018 01:00 PM
thefishguy77
Jul 30, 2015 10:59 AM
luckypig44
Jul 19, 2015 11:25 AM
