Please help troubleshooting my 99 4runner 3400 V6
The motor idles smooth.
Runs extremely rough under power, almost "skips" like the timing is going crazy. Strong weak, strong, weak, vvvvttt ,vt, vvtttt, vvvvvtttttt ....
Is pulling random misfire codes p300 and cylinders 3+4+6.
Compression in all cylinders is fine and holds.
The #4 plug was black, not tan like the other 5.
The #1,3+5 injectors measure fine.
If anyone can help point me in the right direction I would appreciate it.
Got a picture of that plug to post?
What type of plugs are your running? I would start checking the middle plug wire, then the middle (#3) cylinder coil.
I'd also check your timing. I remember one member who only got a CEL when driving at high speeds, low to idle was fine. It turned out his crank bolt pulley was never tight, leading to a good bit of trouble in the bottom end.
Great! Check that #4 after some miles and see if it gets black again....there still may be something going on there.
Flying91
45
Apr 11, 2024 04:39 PM
BeMiceElf
Oct 10, 2015 09:40 PM
Avenged
Jul 9, 2015 07:55 AM
