Rim caps
Old Nov 4, 2010 | 08:13 AM
Waylayer's Avatar
Rim caps
I have a set of alloy rims on my 93 pickup. The rim caps on the rear fit but not on the front. Ive been trying to figure what style rim caps will fit on front.
Old Nov 8, 2010 | 12:49 PM
Nervo19's Avatar
Are you having trouble fitting the hubs with manual hubs? Look at "kiyobrown's" buildup thread. He has these center hubs on a First Generation 4Runner. He said Toyota sells an "open hub" version. You could also take a dremel tool and cut the center out of the cap.
Old Nov 8, 2010 | 01:16 PM
clydehatchet's Avatar
x2. use a dremel. have seen it many times. also, you could find some off ebay from a 4wd pickup.
Old Nov 13, 2010 | 05:22 PM
Waylayer's Avatar
I was going to cut a hole in them but at some point im going to get some black steel rims and sell the stock ones. Ill check out ebay for now. Those hub bolt caps are pretty vulnerable with out a cover cap of some sort.
1uzRunner
63
Nov 10, 2018 03:58 PM
HiLuxer
Jan 6, 2016 11:34 AM
Bill McBride
Sep 20, 2015 02:51 PM
larrys93pickup
Sep 17, 2015 07:05 PM
AkitaDog
Sep 3, 2015 09:01 PM
