Idler arm.
Old Nov 1, 2010 | 07:57 PM
G Russell's Avatar
Idler arm.
Hi folks,
I have a 1985 4wd long bed truck. I want to replace the Idler arm bushings but cannot find it. All I can find is a push rod coming from the steering unit arm connecting to the wheels with some play. Can anyone direct me in the right direction. Is there a difference in 4wd, 4runner and 2wd. From what I can see I do not have an idler arm.
Thanks,
Gordon
Old Nov 3, 2010 | 08:02 PM
TroyToy's Avatar
85 is a straight axle and does not have an idler arm 86 up
Old Nov 12, 2010 | 09:40 PM
the_supernerd's Avatar
Straight axles came on 4x4s until 1986. They do not have an idler arm. Later independent suspension 4x4s and all 4x2s had idler arms. If the rod coming from the steering box has play in it, then that is why your steering is loose (which is the reason you were probably looking for an idler arm ).
Old Nov 13, 2010 | 01:44 AM
drew303's Avatar
You would be correct. =)
Old Nov 13, 2010 | 01:47 AM
toyotabull's Avatar
What is your reason for wanting to replace idler arm bushings, regardless if your truck doesnt have one, but is it because of slack in the steering? More info= more helpful answers.
ladybugRC
458
Aug 21, 2020 10:41 AM
Longbed 90
Mar 11, 2019 12:38 PM
YotaPagota
Sep 20, 2015 06:24 PM
Kylenicoll33
Sep 17, 2015 08:40 AM
ptb12
Jul 5, 2015 01:49 PM
