dual rear axle 4x4?
Old Oct 30, 2010 | 02:07 AM
Rusted Rooster's Avatar
dual rear axle 4x4?
Anyone know if a toyota dual rear end, like out of an old yoda u-haul will bolt up to a 87 4x4 truck?
always wanted a 4x4 yota dulley,,, any help would be great!
And are the 1 ton dulley truck frames the same as standard ones,,,guessing just the leaf springs are bigger, that makes it called 1 ton? Thanks again.
Old Oct 30, 2010 | 07:10 AM
lephturn's Avatar
Probably would. I think I remember seeing a lifted 2wd dually all customized. Wish I had pics ofit.one thing to remember Isis the rear end gearing has to be the same as the front or havoc will happen. I know first hand when I changed the gearing in my ram dually.
Old Oct 30, 2010 | 07:23 AM
needsomecam's Avatar
i have a dually and yes the rear end will fit yur truck. the dually rears are 4.10 gears and are the standard 8in rearends, so if you want a locker you wont have a problem doin so. fyi 1 ton trucks are long bed 2wd trucks with an added girdle to the front end, and large leaf packs in the rear.
--chris
Old Oct 31, 2010 | 04:03 AM
Thanks for feed back guys! I learn so much on this site.
Old Oct 31, 2010 | 08:05 AM
tried4x2signN's Avatar
From: Nashville TN. I can help you if you're close BUT NOBODY CAN HELP YOU IF YOU DON'T FILL YOUR LOCATION IN!
arent the rims a funky, odd bolt pattern?
And you think you want a dually, but you'll be over the hard to find tires and goofy looks before too long.
It'll take you longer to find and match all the parts you need...
Old Nov 1, 2010 | 01:45 PM
parts aint to hard to get, yes there is only one style rim for them but they are a 14 in rim so there are plenty of tires out there tht will fit
Colington
Mar 8, 2020 09:51 AM
jerusry
Oct 19, 2015 05:28 PM
ItsJustD
Jul 7, 2015 07:49 AM
Nickdigg
Jul 7, 2015 06:04 AM
toyoda8488
Jul 5, 2015 10:18 PM
