4x4jeffyota's 1986 Pick-up Build-Up Thread
Old Oct 17, 2010 | 06:09 PM
4x4jeffyota's Avatar
Hello!!!! My name is Jeff and I bought this 1986 22r Pick-up in Jan. 2010. This truck is my first Toyota and my first 4x4. I bought it from a Dealership in Southeast Missouri for $2000 cash.
Old Oct 17, 2010 | 06:11 PM
One day I got bored and came across some Red engine enamel and got to thinking.
Old Oct 17, 2010 | 06:14 PM
Theeennnn, my brother and I were at my uncles house playing with his welder and did this with some fog lights from Walmart for $20. I painted them flat black.
Old Oct 17, 2010 | 06:19 PM
I bought the push bars w/ lights for $50. They guy didnt have any mounts for it so I got my lil bro to weld it on. And I also gave $50 for the homemade roll bars with the lights.
Old Oct 17, 2010 | 06:40 PM
Here are a few pics of my current project I started today. I removed my flooring and seat. I plan on installing some seats from a Civic or something and spraying some Rhino Liner down.
As you can see, I have some rust to take care of.
I tried for almost an hour with a scrapper to scrape the thick rubber matt stuff with not much luck. So grabbed the Ol' soldering iron, hahaha.
And 1 and a half hours later....haha
As you can also see I need a new seat
Anybody have any better ways to getting that rubber matt stuff up. I also tried to use my wife's hair dryer but it took too long as well.
Old Oct 17, 2010 | 06:44 PM
The plate you see in front of my gear shifter is there because the tranny I just installed is from an 85 and everything is located about 2 1/2 inched back. I also had to cut a small section out of my seat b/c while in 4hi the seat would push the shifter into N.
Old Oct 18, 2010 | 09:40 AM
I'm trying to get my front sway bar off but the long bolts are stuck. I was wondering if it would be fine if I just used a sawzaw?
Old Mar 30, 2011 | 10:11 PM
oops, I forgot about this, heres my new/used welder and brand new mig gun and assembly. I traded my $130.00 wal mart brand stick welder for a $400 Lincoln 115v Weld-Pak 100 Flux core welder. The original gun was broke when we traded. Thats why I got such a good deal.A cheap gun and assembly was gonna run about $135.00. So after I got home Monday I emailed Lincoln Electric and told them about my gun being broke and ask if there was anything they would do to help me. And they said normally there stuff is only on a 90 warranty but this once they can make and help me out and sent me a free gun and entire assembly for free. Which would have cost me $192.00 if I had bought it. And it's 2 days later and the pakage arrived!!! I coulnt wait to hook everything up to see if it worked. And it works great!!![IMG][/IMG] [IMG][/IMG]
Old Mar 30, 2011 | 11:58 PM
nvtoyota's Avatar
Great truck have fun with it I do not know if you have a heat gun but that is what a friend of mine used on that rubber mat stuff or a propane torch like they sell at walmart just be really carfull not to make the floor to hot next to the fuel lines or electric
Old Mar 31, 2011 | 06:36 AM
I prolly use a heat gun, i need to go buy one anyways. thanks
Old Mar 31, 2011 | 06:38 AM
does anyone know if my welder is strong enough to weld new shock mounts and spring mounts and to make some sliders?
Old Mar 31, 2011 | 06:48 AM
this happened about a month ago[IMG][/IMG][IMG][/IMG] I decided to take my push bars about and made this, I plan to build a new bumper soon
Old Mar 31, 2011 | 06:50 AM
My uncle made this receiver hitch at work for me. The hook is from my push bars. I still have one more hook, any ideas on what to do with it?
Old Mar 31, 2011 | 09:54 AM
My first bead with my new/used Lincoln Weld-Pak 100. And this is only my second time ever picking up a mig/flux core. I welded some 3/8 steel together and pounded very hard with a hammer and it didnt budge,crack or break. I am extremely happy with this welder.
Old Mar 31, 2011 | 10:07 AM
nvtoyota's Avatar
You should be able to weld you're shock mounts and sliders just fine as long as you get good penetration ya know I think you will be fine as long as you don't try to weld half inch plate to you're truck
Old Mar 31, 2011 | 10:53 AM
yea i think the absolute thickest im gonna weld it 1/4 but mostly 3/8 i reckon
Old Apr 18, 2011 | 07:59 AM
I've decided to remove my rear bumper b/c it keeps getting caught when I climb steep stuff.
And yesterday I was wanting to play with my welder and I decided to make stinger with my winch plate. I cut the light protecters from my grille gaurd and bent them out a little and welded them together. Not the prettiest stinger ever but its a start until I get some metal to fab up a bumper. I have 2 brackets made out of 1/4 steel with hole drilled in them. Im going weld them to the winch plate and hang D rings from them. Im gonna get them welded up sometime today.
Old Apr 18, 2011 | 08:03 AM
Heres my buddies MJ with a 5in lift. Our truck look a lot alike.
Old Apr 18, 2011 | 08:09 AM
And heres a video of his MJ flexing a little.
http://www.youtube.com/watch?v=9qcsH28wfiw
And a gay little video with my truckie!!!
http://www.youtube.com/watch?v=C3o9782fi6c
Old Apr 19, 2011 | 09:37 AM
nvtoyota's Avatar
well at least you got out there and played a little. you should look into raising you're rear bumper up instead of taking it off you know in-case a stump or something should sneak up on you. don't want to ruin the bed and end up with a lot of body work
