BE SAFE when working on your Toyota! Please read this post
Old Oct 8, 2010 | 11:05 AM
hross14's Avatar
this will be a quick but important post--at least i think so..
This has been bothering me for some time--but when i was replacing the front main seal on my truck i almost killed myself.
Here is how.....
with the front end of the truck jacked up and well seated in jackstands--I tore apart the front half of the motor and was rotating the motor with a large breaker bar. it was hard to rotate and i just chalked it up to being a new motor with the plugs still in. Finally i took a break and can you imgine what i saw?? The truck was moments away from falling off the jackstands and smashing me against the garage wall.
I kept the truck in gear (Its manual) and only chalked the rear side of the tires!!! as i was turning the motor and checking the timing belt marks it was slowly moving forward.......
Lesson learned--somtimes being tough and stubborn can get you killed. When you are having issues--see what is happening and then continue on.....
Thanks
Old Oct 8, 2010 | 11:19 AM
swampfox's Avatar
Words to live by.
Old Oct 8, 2010 | 11:22 AM
Ron Helmuth's Avatar
appreciate the sentiment-sometimes we get so wrapped up in what we are doing we fail to step back and see the whole picture. I've certainly done it.
lledwod
Sep 6, 2016 07:33 AM
gog1968
Jun 22, 2015 05:55 AM
bobbybouche
Jun 18, 2015 10:22 AM
