does the driveshaft to the front axle extend on an '84?
I have an '84 longbed pickup and had a problem with the front axle. The passenger side you bolts were loose so the centering pin broke. Now I have it all back together but the front drveline doeant seem to extend. Is that normal?
I was able to reconnect everything so it must have moved some, but I couldn't extend it manually. Had to cinch it with the bolts. My 47 willys jeep extends more and more freely. So do they only extend a few cm. On these trucks? Thanks for the quick response by the way!
The driveshaft better well move in and out. If you go over a bump, the front axle moves up therefor shortening the driveshaft. If the front axle moves down the driveshaft needs to extend out. If it does not move, you need to either unstick the spline somehow or have a new one welded in and have the shaft rebalanced. While you are at it, check the rear driveshaft.
FS[GreatLakes]: Toyota collection part out
88sasturbotoy
Jan 30, 2026 01:57 PM
jerusry
Oct 19, 2015 05:28 PM
