93 v6 manual pickup no fuel/spark
need help died while driving not getting fuel or spark it seems. replaced fuel filter cap and rotor confirmed fuel to rail but injector and spark isnt happening. when i put the key in and turn to on the check light doesnt come on so im figuring its the ecm that needs replaced vs the igniter.
if someone has any toyota that has the same ecm that live near portland OR i live in forest grove and would love if you would allow me to test those parts on your running vehicle to determine for sure if its the issue before spending more money on it. email me or call/text 5o3 73o 9455
Ross
Ross
bump
tested the igniter and ecm neither are getting triggering anything. trying to get a distributer to test with, and will be trying to tace wiring from the ignition to the ecu if anyone has any problem leads that they can think of
appears to be fixed as of now. mechanic found a short out in the air meter that was causing the no fuel and no spark issues and caused the distributor to fail as well. wife is on the way to pick it up now.
hope this can be a help to someone else
nanhodges2733
May 29, 2020 03:28 PM
Sep 4, 2015 09:27 AM
Poncho0206
Jul 10, 2015 06:21 PM
