22rte guys come in- wideband?
Old Aug 10, 2010 | 11:55 AM
greatskiiiier's Avatar
hey, just recently got my first turbo and want to crank up the boost a lil. ~9psi, just enough to power 33s without any issue
i already put a straight pipe in place of the cat and have a flowmaster 2.5" catback, i also cut the intake box and put a k&n in there, and put a straight 3/8 line from the radiator to the turbo
i plan on putting a boost gauge and manual boost controller in but not sure if i REALLY need a wideband, i know everyone I've been talking to says i do, but I rather not spend the $300
I also read that the stock ecu can handle up to 10psi, any thoughts?
Old Aug 10, 2010 | 06:31 PM
Flash319's Avatar
My understanding is that the ECU does not read wide band so no point. The ECU looks for cyclic swing not a value. Widebands output a voltage based on the O2 content and the ECU then adjusts based on a value. Standard O2 sensors just give High or low content not an analog value.
Old Aug 10, 2010 | 06:48 PM
shaeff's Avatar
With ANY modified turbo vehicle, it's a good idea to have a wideband. Even better to have one in conjunction with a tuning device, so you can net the most power safely from your motor, all the while getting better gas mileage when tuned properly.
Old Aug 10, 2010 | 06:59 PM
i wouldnt consider 2psi and bolt ons "modified" but i know what you're saying... but even with 9psi i should have a wideband? and cant i just tune it by the AMF?
Old Aug 10, 2010 | 07:16 PM
# If you've added a free flowing exhaust and a K&N (or similar) filter, you can probably adjust your AFM 1 tooth richer.
# If you've modestly increased boost, you can probably adjust your AFM 1-2 teeth richer.
found that on Jeff's site, so I think if i turn it up 3 clicks I should be good to go with only a manual boost controller and boost gauge
polo451
13
Nov 20, 2016 07:49 PM
coffey50
Jul 28, 2015 10:55 AM
toofly1999
Jul 25, 2015 07:09 PM
timmJ
Jul 7, 2015 02:01 PM
karbin
Jul 5, 2015 11:37 PM
