will the ZUK coil mod help level m y rig from side to side?
Old Apr 27, 2010 | 03:36 PM
8yota6's Avatar
my rig is leaning alot to the drivers side thinkin of doing the ZUK mod but not sure if it will work. any thoughts would help.
Old Apr 27, 2010 | 03:49 PM
CapeRustBucket's Avatar
Are your leaves worn out
Old Apr 27, 2010 | 03:54 PM
8yota6's Avatar
i looked at the length of the bolts for the tbars and they were pretty close to the same. should i try adjusting those first?
Old Apr 27, 2010 | 03:59 PM
try either overadjusting the drivers side or just replace them, it looks like they're worn out
Old Apr 27, 2010 | 04:03 PM
8yota6's Avatar
thx i will try that first
Old Apr 27, 2010 | 06:22 PM
94dailyget'er's Avatar
OK so im a newb, but know what the zuk mod is just dont understand the point of it over just replacing the leaves, any info.. the rear of my 94 pickup sags a little compared to the front.
Old Apr 27, 2010 | 06:26 PM
camo31_10.50's Avatar
to the OP...i think if the torsion bar adjustment doesn't work, then you will have to get something like a 14" 100lb coil for the passenger side..and a 14" 125# coil for the driverside LOL
Old Apr 28, 2010 | 08:26 AM
rattlewagon's Avatar
make sure you dont have a broken leaf. Might just want to replace thoes also.
Edit: what are you running in the back? lookl like a block/antiwrap bar?
Old Apr 28, 2010 | 03:39 PM
8yota6's Avatar
i found out those are traction bars that jeeps used back in the day. some guys on here helped me figure that out in another thread.
Old Apr 29, 2010 | 07:14 AM
ZUK's Avatar
ZUK
I recall that two of the guys that did install the coils did report that it rode a ton better AND took the lean out they had. So, it might fix you up. Be aware that lean can be caused by not only a tired leafpack but also by a bent shock or even a curved leaf perch. ZUK
Old Apr 30, 2010 | 06:06 PM
Junkers88's Avatar
The ZUK mod is a better option than replacing the leaf springs.
1) It gets the rig up to (or above) factory ride height depending on the coils.
2) Coils don't sag over time.
3) The spring rate of the coils cuts down the body roll.
4) The coils offer a better weight capacity.
Just so you don't think I'm talking out of my @$$
https://www.yotatech.com/forums/f116...ks-zuk-157035/
In my current rig I haul close to 400lbs of gear on a camping trip. Camping box, spare fluids, spare parts, spare everything and it carries that weight with no issues.
OP. Your rig looks to have either a busted rear leaf pack or an issue with the TB on the drives side. With that kind of lean I'd be doing a complete inspection of the suspension mounting points on the frame and a serious look at the rear packs.
Old Apr 30, 2010 | 06:12 PM
BigBluePile's Avatar
Get some wider tires...
Old Apr 30, 2010 | 06:18 PM
Junkers88's Avatar
Dork. Those freaking swamp-gumbo mudders are huge already.
Oh and nice write up on the roll-bar-speaker mod. Well done VP.
Old Apr 30, 2010 | 06:38 PM
They ARE?!?!?!!?... lol
You're welcome, cheap and effective.
Old Apr 30, 2010 | 06:59 PM
Junkers88's Avatar
I may have to fine you for that. No wheeling for a 10 days, and 5 Hail Yota's.
Old Apr 30, 2010 | 09:49 PM
ehehhe
msane99
Jul 11, 2015 08:08 PM
icentropy
Jul 11, 2015 07:21 AM
akaphilly
Jul 9, 2015 02:18 PM
Nickdigg
Jul 7, 2015 06:04 AM
toyoda8488
Jul 5, 2015 10:18 PM
