Getting the kinks out of new 3.0L
Few back ground notes. I purchased a 1990 4Runner Automatic 4x4 with typical V6 headgasket issues. Turned out to need an rebuild/new motor. I threw in a long block and am now trying to get the remaining kinks out of it.
Here are the symptoms:
1. Once it warms up and the idle drops from the initial high speed warm up, it wanders up/down and sputters once in a while.
2. The Check engine light is not on, however if I pull the codes I get a Code 51 or TPS code. I have been unable to clear this code.
3. It will run/ drive great, then randomly not down shift. When it does this the O/D light blinks. If I stop the vehicle and let the rpm's drop to idle, the O/D light turns off and tranny will function properly. Again this is not consistent and occurs randomly.
4. The truck is a 3.0l Auto, with a 4" suspension lift and 33x12.5 tires. The best fuel mileage I am getting is 13mpg highway with ECT switch in econ mode. I know the 3.0 is not a great gas saver and the 33's do not help, but I expected better mileage than a half ton small block.
Any ideas on these issues?
smilen724
13
Nov 8, 2015 04:11 PM
meatballs
Sep 16, 2015 06:25 PM
