double to single timing chain, spacer?
So im replacing my old timing chain for a new one and i went the single chain route this time. I noticed when i installed the new crank gear that there is a gap between it and the oil pump drive, has anyone ever had this problem will it still work? thanks.
From: Nashville TN. I can help you if you're close BUT NOBODY CAN HELP YOU IF YOU DON'T FILL YOUR LOCATION IN!
copy that... You need the oil pump drive spine out of a dual row...
Any from a 20R to 83 22R.
Regency
20
Jan 3, 2020 07:43 PM
icentropy
Jul 9, 2015 02:12 PM
