Help with a starting problem - 1998 Tacoma 3.4L
Old Apr 3, 2010 | 05:44 AM
B. Graves's Avatar
Alright, my truck did this one time like 3 weeks ago and did it again yesterday. When i went to start it, it fired and died immediately. So, i started it again and it ran good for a few seconds the sputtered and died when i gave it gas. both times i turned the key to the off position and then started it back up a third time and it ran great. Like i said, its done this 2 times about 3 weeks apart. It is a 3.4L 5-speed 4X4 98 tacoma. What do yall think could be causing this?
Old Apr 3, 2010 | 07:04 AM
hilux1026's Avatar
when was the last time you did a general tune up.... plugs, leads, filter, usual items??
Old Apr 3, 2010 | 07:10 AM
Fink's Avatar
Renamed your thread - first one was pretty ambiguous.
I agree with the tune-up idea, might also look at doing the fuel filter.
How many miles on it? Any work been done to it recently?
Fink
Old Apr 3, 2010 | 06:22 PM
B. Graves's Avatar
just turned 100k miles, just did a fuel filter recently. no work done recently. ill look into plugs, wires and all that good stuff i guess. probably due.
Old Apr 3, 2010 | 07:17 PM
Fink's Avatar
Fuel pump might be going bad but with only 100k on it I doubt it.
Fink
Old Apr 4, 2010 | 05:34 AM
atistang's Avatar
could be the check ball in the fuel pump that keeps fuel from draining out of the lines
if this becomes a problem that happens every day then try turning the key on for 5 seconds, then back off, then back on for 5 seconds, then back off, then back on for 5 seconds, then start it
if it starts normal then it is probably the check ball
the1998sr5
Oct 19, 2016 12:48 PM
B. Graves
Jul 3, 2015 04:10 AM
renorunnerguy
3.4 Swaps
Jun 28, 2015 09:18 AM
P51warrior
Jun 25, 2015 05:50 AM
ACZR
Jun 23, 2015 07:55 PM
