replacing front struts on 2000 tacoma prerunner
Old Mar 11, 2010 | 01:12 AM
dniesy06's Avatar
Post replacing front struts on 2000 tacoma prerunner
Following the manual, I removed the the entire strut/spring assembly. put the new strut on the original spring. But, when i tried to put the assembly back on the truck, it seems to long to fit. I have the top three bolts attached but cannot compress the spring/strut enough to get the bottom bolt through. Need help please!!!!
Old Mar 11, 2010 | 04:31 AM
eddieleephd's Avatar
when I did this on mine I had to use something to pry the lower a-arm down to get mine together also you can use a farm jack and a chain to help compress the shock slightly still being able to move it around to line up.
PureTacoma_Tundra
PureTacoma_Tundra
Jun 29, 2015 09:45 AM
ACZR
Jun 23, 2015 07:55 PM
88Toy
7
Jun 17, 2015 09:40 AM
