Help me choose a gear ratio
Old Mar 10, 2010 | 01:19 PM
vwluv10338's Avatar
Well this is just about my first post and I need some advice. I just bought an 89 'Yota x-cab V6 auto. It has 250K miles with a rebuilt engine. I want to change out/rebuild my diffs for two reasons:
1. The truck has 4.10 gears with 31 inch tires and can't get out of its own way.
2. There is a whine in the rear from the diff I believe. So I either need to rebuild/swap the diff and do axle bearings.
It is my understanding that a 4cy with 31" tires would have 4.88 and a V6 auto with 31" tires would have had 4.56. Correct? I would like to get it as close to stock as I can. I love the look of the 31s and am most likely not going much bigger (if at all) than that.
I went to my local salvage yard and there are a few nice cash for clunkers 4-runners on the lot. There is one G284 4.3, and a few G144 3.0L V6 auto which would be 4.88 correct? I am confused because I didnt think the 4.88 would come in a v6 auto, just the 22r. According to the gear calc my stock 4.10 w/ 28" tires would be spinning 2248rpm @ 65mph. If I went with 4.88 w/ 31" it is 2441rpms @65mph. That doesnt seem like I am giving up much top end if I gain more acceleration.
Am I correct that they have 4.88? Should I buy and swap them if they are correct? Would it even be worth the trouble to swap in the 4.3?
EDIT: So I searched the forum as opposed to just reading the stickys. So G144 is correct for 4.88s on the 92 4 runner that would have had 31 in tires. Since I have the same 3.0l and possibly the same auto then I would think 4.88s would be perfect as I would be just stock for the 4-runner correct? Also, the front is a ADD but I can just swap my axle tube onto the 4-runner diff to eliminate it right?
Sorry for all the questions. I hate being a noob but I dont want to buy the wrong thing.
Thanks,
E
Old Mar 10, 2010 | 02:14 PM
874runnersr5's Avatar
go with the 4.88s
Old Mar 10, 2010 | 04:48 PM
a4runnerfreak's Avatar
From: Grew up in S.C.V, So Cal.....now in Hampstead, NC
Up until '91, the V6 with auto trannies were under-geared with 4.56's. In '92, Toyota put in the 4.88's. And this is with the 31" tire package. Go with the 4.88's
Old Mar 10, 2010 | 05:03 PM
vwluv10338's Avatar
So it seems like the 4.88 is the consensus. That is good because in the two junk yards 10 minutes from my house there are 4 to choose from. Two of them are so clean I might get the seats as well.
Old Mar 10, 2010 | 05:16 PM
Stuwy123's Avatar
Get the 4.88's and you can run 33" tires and have plenty of zip.
I'm running 4.56's and 33's, it's not bad but a little hard on the clutch on the hills and the added power would be helpful off-road.
the1998sr5
27
Nov 17, 2015 09:30 AM
thzpcs
Oct 3, 2015 07:39 AM
wolfpackfan33
Aug 2, 2015 03:36 PM
Shaun Crystal Gomban
Jul 30, 2015 10:13 PM
justdifferentials
Just Differentials
Jul 22, 2015 08:26 PM
