bob and cab swap question
I have a single cab short bed 84 sfa
and i need the extra leg room and want to put a extended cab on it
as well as cut out the front of my bed the 9 3/4 inches i think it is. and bob the rear of the bed as well so super short stubby bed
but my question is before i go buy a cab is
will it bolt right in for most of the mounting points that the single cab uses
or is this more of a hastle then it really is worth
leg room is nice but i dont want to dump alot of money into just to make it work and half ars is.
TIA
basket.
TIA
basket.
tons of people have put an X-cab on a standard frame.
No is it not a direct bolt on. The rear cab corner mounts are different.
Easy thing to move the mounts if you can cut and weld. Might have an issue with the horseshoe frame
edit: used the google for toyota sites in my sig and found some of these-
http://www.pirate4x4.com/forum/showt...standard+frame
toyoda8488
Jul 5, 2015 10:18 PM
