1986 4-Runner wont start! help!
Hey everyone I just singed up to this forum as I am a big fan of Toyota 4x4's! It looks like there is allot of great info on this site. I am considering buying a auto 1986 4-runner 4x4 with the 22re and 189,xxx miles, but when i went to go check it out it wouldn't start without jumping it. The truck will try to start, but sounds like it doesn't have enough battery power to fire up. But when its jumped it starts, idles, and runs fine. The guy said its been sitting along time and needs a new battery. I went to his mechanic with him to have it checked out and they tested the battery which was fine (14 volts) and he also checked the alternator which was also fine (14 volts). I was thinking it could maybe be the starter, but I thought a bad starter made a clicking noise. I am going over to buy it in the morning, but I would like to know why it wont start. Any help would be greatly appreciated. Thanks!
How did they test the battery ?, did they load test it ?, it sound like a bad battery to me, because you said if you jump it - it will start. I would try a different battery that you know is good and go from there.
They did hook both alternator and battery up to the load test machine to test them. I noticed that he only tested the battery when it was running. Does that make a difference? Does a bad battery show good test results when the car is running and bad test results if the trucks off? Thanks
We decided to buy the truck today, jumped it and drove it home. So I guess I'll just try getting a new battery and see if that will fix the starting issue. I have a quick question, what is the normal/power button near the shifter do? Also the guy that sold it to us said that when you go on the freeway push the overdrive button and when your driving the streets have it off. Is it necessary to have overdrive on when driving freeway speeds? thanks
I did try cleaning the terminals, but it still wont start. I took the battery over to autozone and they said it had abaut a quarter charge. I don't know if that would cause it to not start, but I left it with them to charge it. I'll pick it up tomorrow and see if was able to be charged. If it was I'll hook it it up and see if she'll start. Also what is the normal/power button do? thanks!
Jun 1, 2021 01:51 PM
I'm glad it was just the battery! Maybee i'll post up some pics tomorrow!
