Does front prop shaft always turn?
96 4 x 4 w/ADD. I just noticed a little vibration in my front at highway speeds. Does the front propellers shaft ourn all the time? I know the front cv axles do, I have ADD. Also the 4W light doesn't come on in dash. It does engage in 4w drive though. I quit using this as my daily driver a year ago. It's a toy now. I drive it once a month. They don't like not driving more often.
No, the front prop shaft should not always turn in 2wd. Sounds like your ADD is not disengaging. I had the same problem with my 94. With the Transfer case in 2wd, you should be able to spin the front prop shaft by hand.
Well my bad I guess, I thought that the front tires rolling (from being pushed by the rears in 2WD) caused the front drive shaft to turn. I'll have to look at mine again sometime. Sorry if I was wrong.
No the prop shaft should not turn all the time , but the axles and haft shafts do .If the fw light does`nt come on check wires on tranfercase I had happen before.To stop it and save wear and tear on the shafts and differential change to locking hubs .
FS[PacNorWest]: Rear chromoly axle shafts
A2theK
Jan 10, 2016 10:18 AM
Iceman4193
Jul 15, 2015 04:48 PM
FS[NorAtl]: some RC stuff crawler and racer
akaphilly
Jul 9, 2015 02:34 PM
