Blinker Voltage Drop? Horn radio connection?
Old Jan 12, 2010 | 02:44 PM
Schmeal Hawk's Avatar
Hey guys, I searched around and couldn't locate a solution to my electrical woes on my 85 SR5. 2 problems
1. When the blinker blinks either direction the voltage meter dips when the light is on then goes back up when the light is off. So it kinda dances when the blinker blinks
2. If I hit the horn the radio cuts out. Before with the stock radio it would go to static. Now with the pioneer it just cuts out (display still on). I have to then power it down then power it back up to get music to play.
Battery is new. I'm thinking its a current starvation issue having to do with a failing alternator? But headlights aren't noticeably dim or anything. Also the battery is charging fine. Truck starts fine every time. Anyone have a clue? Thanks for reading.
Old Jan 12, 2010 | 04:39 PM
dustins's Avatar
Have the same issue with the blinker, and just replaced the alt. and have good battery
Old Jan 12, 2010 | 05:11 PM
phildelfino's Avatar
usually a bad ground. check battery to body, body to frame, battery to engine. check alt. voltage output. battery voltage.
Old Jan 12, 2010 | 06:05 PM
AbeWhat's Avatar
You can rebuild the alternator for $5 too if you don't want to replace it.
Old Jan 13, 2010 | 12:51 AM
stormin94's Avatar
I thought I was the only one with the blinker dancing. Guess not...
Old Jan 13, 2010 | 12:56 AM
malteserunner's Avatar
My blinkers get jiggy too!! Maybe we should start a club?
This is one of those issues that's been on my list for a while. Too many projects going on at once, so I'm just living with it for now. I figured it was a ground issue, or crappy old wiring to the blinkers.
Old Jan 13, 2010 | 02:30 AM
klinc207's Avatar
Same problem here, I'm going to assume a bad ground. With the negative switching ground that Toyota uses, where does everything ground to? Back to the battery? or a terminal block somewhere?
Seems like theres enough of us with this problem we should be able to get to the source!
Old Jan 13, 2010 | 08:10 AM
4runner4life93's Avatar
I have the same problem when i hit my horn it just clicks and my blinkers get jiggy
We need to get to the bottom of this
Old Jan 13, 2010 | 08:18 AM
https://www.yotatech.com/forums/f116...rite-up-33526/
Old Jan 13, 2010 | 09:16 AM
Had my alternator and battery checked last night at the auto parts store and everything is fine. Going to look into the grounding and other connections. Thanks for the responses!!!
80Truck
Oct 12, 2025 07:25 PM
ghostmoney
Jan 28, 2018 11:42 AM
mussy01
Dec 13, 2016 08:20 PM
theking11863
Mar 19, 2016 09:36 PM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
