Power Steering
Old Nov 8, 2009 | 06:08 PM
PickupMan's Avatar
Power Steering
I own a 89 Pickup. I was wondering how difficult it would be to put a new power steering pump in? I don't want to have to take it to a shop. Also it has a Sunwest 22RE in it. Thanks in advance for all the help.
Old Nov 8, 2009 | 06:12 PM
crawlerjunkie's Avatar
an afternoon, a pwr steering pump, and some tools. Not really that bad.
Old Nov 8, 2009 | 06:14 PM
PickupMan's Avatar
What are the steps to do it? Is there an article on it up already?
Old Nov 8, 2009 | 06:44 PM
drew303's Avatar
drain the fluid out by whatever means you think is the least messy (goodluck)
remove the belt (untighten the 19mm nut on the idler pulley, then adjust out the 12mm bolt to loosen belt)
remove the lines from the pump then unbolt it from the bracket.
Reverse order to install. Fill system with ATF ... fire the motor up and turn the wheel back/forth repeatedly and then keep filling the resevoir till its full and all noises are gone..
done
Old Nov 9, 2009 | 04:12 PM
buckz6319's Avatar
not hard at all.... just remember that you can buy just the pump(rebuilt) and reuse your reservoir.... or you can buy the entire unit pump and reservoir (rebuilt)...or I think you can buy a new one but it's much more $$
Zpd426
Jan 2, 2016 01:15 PM
delmert
Sep 30, 2015 04:34 PM
Up&Down
Aug 11, 2015 10:04 AM
toyoterferdayz
Diesel Swaps
Jul 27, 2015 05:25 PM
gmonnie123
Jul 26, 2015 02:44 PM
