93-98 T100s All T100 trucks
3RZ starts fine ,runs rough after warmed up
Old Oct 25, 2009 | 11:58 AM
TORTIS's Avatar
Still battling this problem. It fires right up, runs smooth, but the minute the temp gauge hits normal running temp, it wants to die, and it starts running like its running on three cylinders . Have to mash the skinny pedal to keep it running. Go out the next day, and the same thing happens.
Something else, sometimes it smokes like the thing does not have rings on the pistons. Couple of days later started it up and no smoke.
It is showing code 0441 on the scanner. Gonna try and fix the valve operating the charcoal canister.
It has a fresh tune up, and fuel filter.
94 3rz 5 spd 384,000 miles
Old Oct 25, 2009 | 08:21 PM
BamZipPow's Avatar
Could be the IAC valve...
Pull it and give it a good cleaning.
BTW...when's the last time you replaced the PCV valve and cleaned the TB?
Old Oct 25, 2009 | 08:58 PM
vital22re's Avatar
totally a bro
94 is a 3vz.... 3.0 v6... unless the truck has the 2.7l 4 banger 3rz swapped in...
Old Oct 26, 2009 | 04:46 AM
TORTIS's Avatar
I don't know . Just bought the truck from a girl and she didn't know anything.
I tried pulling the pcv, but it was one with the grommet.
Old Oct 26, 2009 | 04:58 AM
BoostinChick's Avatar
When was the last time you did a compression check? Vacuum leak test? Fuel pressure test/replace fuel filter?
Old Oct 26, 2009 | 08:31 AM
BamZipPow's Avatar
Actually...the 2.7L was introduced part way through 1994 but only on the basic T-100 not the SR5. In 1995, they had all 3 engines available on the T-100s but the 3.0 was quickly phased out.
Even the chart here confirms that...chassis code RCK10.
Old Oct 27, 2009 | 09:09 AM
TORTIS's Avatar
Fuel filter was replaced.
This truck is thirty minutes from here at a friends house. It has been raining damn near everyday since I bought it, so not much time to work on it.
Fuel pressure was fine. Going to day a compression check tomorrow.
It is a 2.7 3RZ with obd2
Where is the ECU temp sensor? It is supposed to be on the back of the head, but I can't see it.
Old Oct 28, 2009 | 12:15 PM
BamZipPow's Avatar
According to the factory wiring diagram...the colors of the wires should be green-yellow and brown/black. Looking at the harness plot diagram...it seems to be near the firewall and near the heater control valve hoses. Look fer the wire colors and that location on the engine and you should be able to find it. My 3RZFE T-100 is out at the moment so I won't be able to confirm until it gits home.
Old Oct 30, 2009 | 01:07 PM
TORTIS's Avatar
Thanks. there is sooo much oil and dirt it is hard to see whats, what.
Old Oct 30, 2009 | 10:57 PM
BamZipPow's Avatar
Okay...just went out and checked my T-100...it's located in a very tight spot. Not exactly sure how yer gonna git to it though. It's where I described it before. If you find the main wire harness in that location...you'll find one branch coming off of the main harness. If you trace that wire to the engine...that's where the sensor is located. With my small hands...it was really tough just touching the sensor let alone trying to see it with my eyes.
I think yer gonna have to take the wire harness up just to see back there. Maybe the valve cover has to come off so you can pull that sensor out. If you need to test it without pulling all that out...I think you'll have to do it at the ECU connector.
Old Oct 31, 2009 | 03:59 PM
TORTIS's Avatar
Thanks Bam. This motor is filthy. I will feel around back there and find it.
Thanks again.
91toybeater
Dec 27, 2015 07:46 PM
puffin04
Jul 10, 2015 09:17 PM
Alex Bessinger
Jun 28, 2015 10:05 AM
slider417
Jun 22, 2015 10:18 AM
jmc88runner
Jun 18, 2015 03:39 PM
