3vze cranks hard but wont start
Old Oct 24, 2009 | 11:32 AM
swapped89's Avatar
So lately i have been havin to crank my truck longer than normal to get it to start. And now today it wont start at all.
1989 3.o 5 speed
its getting fuel(i can smell it at the tail pipe.
Cranks no problem
All fuzes in engine bay and in cab are good.
The coil has power
I cant figure it out its just not getting spark
Anyone had this prob before
And dont tell me my problem is the 3.0 thats just hatin.
YES i searched
Thank you, swapped89
Old Oct 24, 2009 | 11:51 AM
mic's Avatar
mic
are your plugs clean and have you checked your wires
Old Oct 24, 2009 | 11:59 AM
90-3vzeslug's Avatar
i'd start with the pickup in the distributor. check that with an ohm meter and make sure that its functioning properly, if it isn't then it's not telling the coil to fire
Old Oct 24, 2009 | 12:05 PM
swapped89's Avatar
ya plugs are only a few months old and the old ones looked good when i changed them out.
My buddy checked the power commin out of the coil to the distributor and it was good too.
I just flipped my coil wire backwards and wiggled the plugs on the coil pack thing and tapped the coil with a wrench and it started. wierd i know. but i have a feelin if i let it sit for an hour it wont start again.
yesterday we also checked the plug wires with a spark tester
My problem seems to be intermitant at the moment
Old Oct 24, 2009 | 12:33 PM
clean the ground for the coil. also a bad pickup generally starts as an intermittant problem (in my experiance with other vehicles anyways) Also when it goes, it's the signal FROM the distributor TO the coil that is the issue
Regency
20
Jan 3, 2020 07:43 PM
rbravo1
Jun 29, 2015 01:34 PM
jmc88runner
Jun 18, 2015 03:39 PM
