Jack tools
Old Oct 20, 2009 | 09:50 AM
karen618's Avatar
Jack tools
Just purchased a 94 pickup. But has no jack tools. I'm sure they are compatible with other year yota's. What years might the be. Any help would be appreiated. I've already searched but did not find the info is was needing. Thanks K.
Old Oct 20, 2009 | 10:06 AM
highonpottery's Avatar
go to a junk yard/ebay/craigslist and pick up a stock bottle jack. make sure you also pick up the basic tool kit that goes with it - which contains the crank assembly that you'll need to use the jack as well as lower your spare tire.
for the garage, pick up a decent sized floor jack (2+ ton), some GOOD jack stands (4-6 ton), and some wheel chocks/blocks. i would also pick up one of those cheap package deals that have a small floor jack, a creeper, and 2x - 2-ton jack stands.
for the trails/emergency, get a hi-lift jack and some sliders w/slider adapter.
those should take care of all your jacking needs.
Old Oct 20, 2009 | 07:56 PM
karen618's Avatar
yes, thanks for all that. I know what I need, i just would like to know what years are compatible with my 94. Like lets say could I use the jack tools from a 97 runner or a 01 Tacoma? In short, what other Toyota years and models can I use for my 94? Thanks K.
Old Oct 20, 2009 | 08:18 PM
peow130's Avatar
A jack's a jack.
It'll work on any vehicle...
Just get all the stuff for the jack from the same vehicle
Old Oct 20, 2009 | 08:22 PM
Magnusian's Avatar
From: Downtown Heckronto, Ontario, Soviet Canuckistan
As far as I've been able to tell anything from 95 and earlier has the same exact jack setup, hope that helps. Dunno about anything after 95.
Old Oct 21, 2009 | 01:03 PM
i think as long as you get a bottle jack that's meant for a Yota SUV/Truck with more ground clearance than a car, you'll be fine. i believe yota cars all come with scissor jacks.
Old Oct 21, 2009 | 01:42 PM
karen618's Avatar
Jack tools, meaning the tools not the bottle jack. Ive already determined 97 runners tools do not work I think I'll have to go with 95 or lower. I'm in need of the tool that lowers the spare. Sorry on my part if I did not describe it correctly. Thanks for the help. K.
Old Oct 21, 2009 | 02:50 PM
i think that ALL toyota bottle jacks are pretty much identical no matter what the year - I looked really quick on eBay and saw that the ones for a newer Yotas look identical to my '93s. they should all have a little eyelet that needs to be rotated to extend/compress the jack vs a pump-style jack. the crank tool used for the jack is the same tool used to lower your spare tire. all it is is a long-shafted crank assembly that has a hook on the end and comes apart for easy storage.
i believe the only other tools in the kit are a lug wrench/tire iron and sometimes a flat-head prybar for hubcaps.
Old Oct 21, 2009 | 03:07 PM
peow130's Avatar
Screwdriver, will lower the jack, lol.
Old Oct 21, 2009 | 03:11 PM
toyospearo's Avatar
I have a full set with the jack included. You pay the shipping (CA) and I will send it out.
The set is off a 94 extended cab. 22re 4x4
Old Oct 21, 2009 | 04:33 PM
karen618's Avatar
thanks pm sent K.
Old Oct 24, 2009 | 03:45 PM
karen618's Avatar
I wanted to give props to toyospearo for coming up with a set of tools. I wasn't looking for a gimme, but he stepped up BIG TIME!!THANK YOU, K.
Old Jan 29, 2010 | 08:56 AM
waterboydf's Avatar
looking for a jack tool kit for my 88 toy 4x4. I really only need the hook piece which was missing when I bought the pickup. Any help would be appreciated. Doug
Old Jan 29, 2010 | 09:16 AM
WatsonToyota's Avatar
hahaha awesome!
RobotMoose
Feb 22, 2020 07:44 AM
Scottcrb
Mar 3, 2016 11:57 AM
BK2TFUTURE
Oct 11, 2015 08:42 PM
May-39
Sep 6, 2015 01:05 PM
