Power steering pulley
22RE power steering pulley- I thought I kept the order of the pulley and hardware intact, but when putting it back on the pump, the pulley seems too far back. Its not inline with the idler pulley, and the PS pump pulley is also rubbing against a bolt head where the idler bracket meets the PS pump bracket. What's the proper order of everything on the PS pump shaft?!
Thats exactly what I have going on, there's a nut, then lock washer, then washer, then pulley, but the pulley sits way too far back, so its not inline with the idler pulley. It seems like there's supposed to be some kind of washer in between the pulley and the pump to space it foreward.
Any help??
Any help??
That was about the biggest brainfart of the year! The pulley sits a little off-center, meaning that the back side is deeper around the shaft hole. Put it on the wrong way and it won't go... flip it over, and it spaces foreward far enough too work.
delmert
Sep 30, 2015 04:34 PM
so I honestly have no idea what's behind it...
