Mystery miss in 88 pickup
Old Sep 18, 2009 | 09:26 AM
pooldoo's Avatar
My '88 Toyota pickup 22RE 2WD (65k original miles) is running on 3 cylinders - missing on cylinder 3. Removing the spark plug wire at idle has no effect. Compression is 175 for all cylinders, getting a good spark, new spark plugs, fuel injectors have been removed, checked and replaced. You can hear injector clicking with a stethoscope. Air flow meter, power relay, fuel pump relay, fuel filter all replaced. Suggestions, please. I'm desperate.
Old Sep 18, 2009 | 10:16 AM
pooldoo's Avatar
Mystery solved
Never mind. We found crud in the fuel rail, and all seems ok now.
Old Oct 29, 2009 | 01:34 PM
03vrod's Avatar
Did you remove the rail when you found the crud.My truck is doing the same thing checkedspark ,injector,valves,added injector cleaner.So I'm considering tearing intake apart to check
icentropy
Sep 16, 2020 02:47 PM
shisha1999
Mar 16, 2016 12:25 PM
Sep 4, 2015 09:27 AM
Yota.Jay
Jul 23, 2015 08:08 PM
