Transmission Cooler Lines 96 Tacoma
Old Sep 1, 2009 | 05:55 AM
kennyyoung's Avatar
Hi guys, I got a leaky transmission cooler line right infront of the fitting as it goes into the transmission... the line is corroded. My question is... can I buy a short length of fuel line (about a foot), connect it to the fitting, put it back in the transmission and attach rubber hose to the other end with clamps to connect it back to the rad? Or....is it a must to have pressure fittings (clamps) to connect the line to the rubber?
Kenny
Old Sep 1, 2009 | 02:03 PM
el-guapin's Avatar
I dont see a problem but you dont wanna use fuel line hose for this. Tranny fluid will eat through it. need to get tranny or power steering lines
Old Sep 1, 2009 | 02:14 PM
pattycakes77's Avatar
i broke one of the hard lines from the transmission to the soft trans hose that goes to the radiator/trans cooler. i ended up buying it from the dealer, i was surprised that it was only about $30 (that was a couple years ago). i know $30 is more than what your suggesting, but if it comes down to buying a new OEM piece, at least you'll know it's not priced super crazy. good luck
Old Sep 2, 2009 | 03:09 AM
kennyyoung's Avatar
Thanks to the both of you, very good information!!! If anyone else has any suggestions or tips for me, it is greatly appreciated..... I'm going to tackle the job this weekend!!!
Old Sep 8, 2009 | 09:45 AM
kennyyoung's Avatar
Well, started to tackle the job the weekend but never got very far..... man, there is no room down there to do anything and on top of that, your working around alot of other corroded lines. These two transmission cooling lines are going to be brutal to replace!!! Plus, the two fitting that enter the transmission are so gunked up with dirt, I'm scared to even attempt to take them out of the transmission. A job that seemed so simple when first thought about, is turning out to be a nightmare!!!
Old Sep 10, 2009 | 04:21 AM
kennyyoung's Avatar
OK..... finally got the job done!!! Took a little longer than planned, but with a bit of patience and alot of ackward postions under the truck, it's finally done. Thank God!!!!
Old Sep 10, 2009 | 05:09 PM
el-guapin's Avatar
smthwsn357
May 1, 2024 07:28 AM
jjrbus
Jul 17, 2015 07:06 AM
TokyoD23
Jul 12, 2015 06:01 AM
Poncho0206
Jul 10, 2015 06:21 PM
Snort
Jul 9, 2015 03:58 PM
