coolant leak i think
I got my truck going good and i looked it over after i drove it and herd a hiss kinda noise and saw kinda a little bubbles coming from the Intake im not sure if what it is all about so any advice
From where the intake attaches to the head? There are coolant passages there. You could try snugging up all the bolts first, but you may need to replace the intake gasket. There are some other coolant hoses around the intake, so rule out any loose hose clamps or anything, too.
If it's just some bubbling, and not dripping/pouring, then yeah, you're probably fine for a bit, as long as you keep an eye on it. It could also be causing a vacuum leak (if it's the intake that's leaking), which won't help your power or gas mileage, but if everything is working ok, and you aren't really losing coolant, then I guess you'd probably be ok. I would want to know for sure what it is exactly, before deciding whether to let it go for a while.
Blamalam
Mar 12, 2022 07:34 AM
WellsR
12
Jul 31, 2015 03:27 PM
itzmywife's
Jul 25, 2015 04:55 PM
Avenged
Jul 9, 2015 07:55 AM
