I had to change out the #1 injector the other day
Old Jul 22, 2009 | 12:38 PM
ltgvolsrock1's Avatar
i have a 92 toyota 22re 4x4. i had to change out the #1 injector the other day. got it all back to gether took it for a test drive and all worked good untell i got home and saw that i had gas coming out of one of my injectors. so i took it back apart. fixed the gas leak. took it on another test drive.... ? got to the stop sign at the bottom of my road. when i started to go it just DIED. i had 1/2 tank of gas. whats wrong ????? it will idel fine and run fine untell you put it under a load. then it will just die. you can crank it back up, but as soon as you try to move it it will quit! help me please!!!
Old Jul 22, 2009 | 12:50 PM
Flash319's Avatar
Sounds like you may not have plugged in one of the injectors properly. I have bend the prongs before. These engines idle very good on 3 cylinders.
Old Jul 22, 2009 | 01:53 PM
not it all o<embed width="448" height="361" type="application/x-shockwave-flash" wmode="transparent" src="http://i1006.photobucket.com/player....00_0656.flv">f
my injeckors are workin.. here is a video of what it is doing
Old Jul 22, 2009 | 02:48 PM
Help i need my truck back!!!!!
ANYONE OUT THERE????????????? ive checked my spark pulgs, the intake gaskets are new, they are pluged up right. could it be an injector? it idel's just like it should. so i dont thank it can be the injetors??? I NEED HELP!!!!
Old Jul 22, 2009 | 06:02 PM
myyota's Avatar
Start with the simple things first, replace the fuel filter and see if that makes a diference, if not then check the fuel presure by cracking the hard line going to the cold injector, and see if you have good presure. A fuel pump can go bad and still work enough to let the engine idle but not deliver enough fuel when you get on the throttle, and that will cause the bog down or just die.
Old Jul 22, 2009 | 06:12 PM
ive changed the fuel filter. i have good fuel pres. could it be the coil ?????
Old Jul 22, 2009 | 06:18 PM
myyota's Avatar
Im not sure, but i think if the coil was bad it would run real ruff or have a bad miss or something like that. you might try testing it and the ignitor to see if they are in spec according to the FSM.
Old Jul 22, 2009 | 06:21 PM
ok ill try that.. thanks
Old Jul 23, 2009 | 03:29 PM
IS THIS PART NEED A GASKET???? IF SO WHAT IS IT CALLED
Old Jul 23, 2009 | 06:17 PM
myyota's Avatar
Thats the EGR, and there should be a gasket between the two. I think i see another problem in the picture, on the thermostat housing there is a temperature sending unit and on yours in the picture the wire is missing, try fixing that and see if it helps.
Old Jul 24, 2009 | 09:34 AM
:d
Thanks man i got it. Not sure what i did but its fixed! Lol no i thank is had some thing to do with the "efi" relay under the hood i played around with it and hey know it runs fine!!!! Thanks!!! What where you saying about the hose i had missing? Where is it? Lol and where does it go? Thanks!
Flying91
45
Apr 11, 2024 04:39 PM
Sleaker
Aug 26, 2020 06:03 AM
the1998sr5
15
Jul 14, 2020 08:35 PM
Eggslinger
Jun 8, 2019 03:32 PM
jasonty
41
Dec 23, 2018 01:00 PM
