popping noise coming from the RIGHT side of the front end
Old Jun 18, 2009 | 01:05 PM
theBurlyone's Avatar
the noise happens when you turn, go over bumps, abruptly come to a stop, or if your off road and the suspension is flexing. The front end was just recently resealed and the bearings repacked. But the noise was there before it was resealed. You can feel it in the passenger side of the floorboard and in the steering. Any ideas
Old Jun 19, 2009 | 10:21 AM
oldgold3vze's Avatar
broken birf? Is it only in 4wd?
Old Jun 19, 2009 | 12:09 PM
crawldaddy's Avatar
Check your mounts on your shocks. My top mount on the passenger side had a loose bolt that wallowed out the hole. Every bump, turn, or movement you could hear and feel it,
Old Jun 19, 2009 | 02:34 PM
No It does it both in and out of 4wd. I'll check the shock mount. If it is worn what did you do to fix it? Replace the mount or what?
Old Jun 19, 2009 | 08:50 PM
"HAWAIIAN PUNCH"'s Avatar
have someone turn ur wheel lock to lock then look at military wrap side of ur front leaf spring, prolly spring shifting side to side making a popping noise i had to tighten my u bolts to cure my noise!
Old Jun 19, 2009 | 09:26 PM
Ron's 85's Avatar
run your wheel full stuff to left and right like he said but sheck to see if your tires rub on your leaf springs, front or back.
i know my steer stops were loose on the knuckles and my mtrs were binding on the rear of the leaf on both side.
truckmike26
Jul 24, 2024 10:24 AM
Daneums
Jun 29, 2015 06:38 AM
miceal383
Jun 29, 2015 12:27 AM
serenity03k64
Jun 27, 2015 07:59 AM
YotaGreenhorn
Jun 27, 2015 07:00 AM
