3VZE need's a metal head gasket who's going to help
well i have found out that well there is none really on the market that makes them i find this really odd since the stock gasket is plain junk and is a common problem
i own 7mgte in my supra has the same fault and metal head gasket solves the issues
some thing needs to be done like teaming up and e mailing cometic http://www.cometic.com/ and the price's are pretty good
some time ago i help them make the 7mgte gasket for the supra and they made it cause the demand was there
so who is game
so who is game
thus are junk and they can leak at one of the cooling jackets
well i called cometic and they do indeed seam intrested they tried befor but it leak like the ebay ones cause of the tooling they were useing was based off the 5vz fe
i gonna send em sstock gasket for them to look at and hopefully alot of intrest so mabye we can get this ball rolling
just think of an end to bhg for ever
most of the time the factory finish is still there and good to go for mhg but as for the head will all ways have to be done smooth and mirror like as possible ( so no big groves or any thing your nail catches on )
Even after over heating? Usually the surface area gets warped even the slightest bit if you pop a HG and over heat (which can sometimes be the case). I know with working with MHG personally that if both mating surfaces are not smooth/decked the MHG can cause issues.
even after over heating most of the time the deck will be square it take alot to warp a deck but it can happen that what flat edge is for and if ti is warp i still slap one on cause rebuilding a motors cost a bit of money
bead type gakset are more forgiveing then stopper based gasket
kgcwb44
Jan 29, 2023 10:02 AM
the1998sr5
15
Jul 14, 2020 08:35 PM
