ok heres a stupid question how do you take off the shifter on a 5 speed
i just did a body lift and want to bend the shifter forward but i cant seem to remove the shifter
Not sure where you're getting hung up, so I'll start from the beginning.
-First, you need to get access to the shifter. So remove any parts of the center console that are in the way. You'll also need to unscrew the shift knob.
-There should be a plate that attaches the the rubber boot, remove it.
-Slide the boot off.
-Remove the snap ring that is holding the shift lever in. It should just slide out now. A pair of snap ring pliers make it easy, but I've done it without them.
there should be a shift collar retainer, unless yours in rusted in there like mine,
you should be able to push down on the retainer, as you are pushing it down, turn it counter clockwise approximately 1/8 of a turn. than it should pop off the two pins
snap ring is found on a Top shift transfer case lever
ok i took it off and used a torch to heat it up and bend it forward. i think i bent it too much cuz i have to reach forward for 1st and 3 gear but w/e everything works perfectly yay
i know this is an old thread, but thank you everyone. I put in my new marlin t-case and shifter bushings, and I couldn't figure out how to get the shifter out.... T case was easy, snap ring... Anyway, THANKS!
coffey50
Jul 28, 2015 10:55 AM
sabine
Jul 18, 2015 03:59 PM
