Camping, Expedition, & Overlanding Gear Discussion pertaining to outfitting yourself with gear for the great outdoors
My camp kitchen build - test
Old Apr 12, 2009 | 05:24 PM
dport's Avatar
Guest
After viewing Corey's thread on the Drifta Kithens, I decided to build one myself to justify some of the power tools in my garage. The materials list was basically 1 full sheet of 15/32 plywood, a few scrap pieces of 3/4 plywood, 2 drawer slides, 3 window sash latches, 1 4 foot piano hinged cut in two. Here is the main box 32 inches X 24 in.
Old Apr 12, 2009 | 05:28 PM
Godzilla's Avatar
Originally Posted by dport
I am testing the post/attachments
If you do not add to this thread and it is only for testing purposes it should go in the appropriate section:
https://www.yotatech.com/forums/f4/
Old Apr 12, 2009 | 05:33 PM
dport's Avatar
Guest
This is the box with the top and back attached. The overhang was left for adding flip up table tops on either side, which I have not done yet.
Old Apr 12, 2009 | 05:51 PM
RMA's Avatar
RMA
I am very interested to see how this comes out , I want to make one myself.
Old Apr 12, 2009 | 05:55 PM
dport's Avatar
Guest
Here is the top cover, which houses one of my coleman stoves. I have one newer LP and one liquid fuel stove. I would have liked to build the whole box a little narrower, but the LP stoves are a good bit wider than the older stoves. The top cover will flip over and the front of if will hang below. It will be supported by a flip brace. This will provided a second surface for the second stove. My wife and I camp with several other cpl's and often end up the "mother and father" of the group, therefore requiring two stoves.
Attached Thumbnails My camp kitchen build - test-dsc00697.jpg   My camp kitchen build - test-dsc00698.jpg
Old Apr 12, 2009 | 06:00 PM
Godzilla's Avatar
Neat stuff. What are you putting on the bottom for legs? Adjustable ones to account for ground variations?
Old Apr 12, 2009 | 06:11 PM
RMA's Avatar
RMA
Talking
A shovel would probably work good.
dport's Avatar
Guest
More pics of the top assembly
Old Apr 12, 2009 | 06:16 PM
Godzilla's Avatar
I figured just to keep it off of the wet and dirty ground since it is just wood.
Old Apr 12, 2009 | 06:56 PM
dport's Avatar
Guest
I'm having internet trouble b/c of storms, so I'll have to post more pics tomorrow.
Godzilla, I am just planning on sealing it with water sealer and letting it sit on the ground. I think it'll be OK since it'll only be on the ground a few days at a time. I think it'll sit pretty level and sturdy do to it's overall width. It has a pretty large footprint.
Old Apr 13, 2009 | 01:08 AM
dport's Avatar
Guest
This is the top, flipped over and suported by the under brace. Notice the latch on the corner. When the latch is released, the front board will just swing down and be out of the way
Old Apr 13, 2009 | 05:55 PM
dport's Avatar
Guest
Here is the 5 inch top drawer. This will house the silverware and 4 cups (shown), and serving spoons/tongs, etc.
Old Apr 13, 2009 | 06:12 PM
dport's Avatar
Guest
This is the rear of the box in the closed position. The hinge in the center swings up and catches on the small block in the center of the top when it's flipped over to provide the second cooking surface.
Old Apr 13, 2009 | 06:22 PM
dport's Avatar
Guest
Here are the slats in the bottom made of 15/32 plywood, 1.5in wide with 1.5 in gaps.
Old Apr 14, 2009 | 12:47 AM
Corey's Avatar
Co-Founder/Administrator
Looking good.
Where did you get the silverware?
I have looked at GSI's and Colman's who make similar ones.
Old Apr 14, 2009 | 06:22 PM
dport's Avatar
Guest
The silverware was picked up at Big Lots for $10. It came with a few other items that I discarded from the gear.
Old Apr 16, 2009 | 03:51 AM
dport's Avatar
Guest
Haha, I just realized my toes are showing in post 15.
Old Apr 21, 2009 | 03:59 PM
whokrz's Avatar
Here is my camp kitchen, few straps and a piece of plywood that doubles as a base for my jack on soft ground.
Old May 1, 2009 | 01:49 AM
dport's Avatar
Guest
Now that's innovative!!! I need to get some updated pics up. I had to cut the kitchen in half, just below the drawers b/c I found a good deal on a camper shell. I mounted 3 buckle style latches around the joint so the kitchen is still stable when in use. I used it for an over night trip last weekend and I am hooked on having a camp kitchen. I also picked up a cheap wire dish drying rack like you set on your counter and made a bracket that lets it hang off the side. I will have some field pics next weekend
Old May 1, 2009 | 03:24 AM
Corey's Avatar
Looking forward to the pics.
I bought a little dish drying rack yesteryear to use with my kitchen setup.
I had a "home size" version in my old camping gear, but it was to big for this new setup.
I had used the prior rack when I had my tent trailer long ago.
You can see the new baby rack on the far right shelf of the setup.
