will a95 4runner 3.0L A/C fit into 2.2L 4runner?
Do you mean the person has the 22re engine?
Well, if so, then the interior related components should fit- evaporator, etc., as long as the years / body style are in the same range. The condenser should fit as well but I'm not familiar with where the compressor mounts to be able to say if the hoses would work or if the compressor would bolt in.
Deathcougar can prolly answer those.
At least I asked about the possibility there was a 22re involved instead of just assuming that since the OP said 2.2L he meant 2.2 (20r), and then I went into what may be interchangeable if the OP did make that mistake.
Well if you ASSume he has a 22RE, then SOME of the pieces will bolt in, but its moot since none of the lines, pump, or even the condensor will work
Help me understand here....
I have an 88 22re 4Runner. Is there a different condenser for my engine than the 3vze has? All my searching tells me there are two condensers- one is 'standard' and the other is 'super-cool'. Which one should I have?
And what is the difference?
I would like to help you more, but like I said, I don't have experience with the v6 and the related differences with the 22re....
... and one of the few people I would recommend help you doesn't seem too interested.
I've priced aftermarket a/c kits for my 91 truck and they end up at around 1200-1600 installed so considering used parts, I'd probably half that price at least.
Well if you're talking about me, i already explained it would not work
The dealer used to offer an install kit that came complete with everything you need. Not sure if you can still get said kit, or maybe find a NOS kit on Ebay?
icentropy
Jul 9, 2015 02:12 PM
