90 4runner v6
90 4runner v6
okay i was told that the 4runners is not good on trails and that they tends to be too heavy to be on trials. i have a 90 4runner v6 and waS TOLD THAT MY 3" bodylift needs to be taken out because if i was to go ruff trails i can tear my flooring up because of the body lift is that true?. and also that v6 had lots of problems? wat should u guys suggested i saw alot of u guys have 4runners and do u guys experience any prob like that b-4?....
Wow, um. Punctuation helps alot.
First off, You shoulda searched, You coulda found a thread about common 3vze problems.
Then you coulda found a thread about the pros and cons of a body lift.
If your worried about it being top heavy with a 3" bl, take it out.
Go on some mild trails get it slightly of camber and just wheel it, get comfortable with it...
thats not what he asked scoobie...
he asked wether or not a 3 inch BL will RIP THE FLOORPAN up...
no... it wont unless you try to lift the truck up by the body...
theres a lot of people running 3 inchers and other than the problems with the bumpers, steering, and brake lines, they havent really had problems...
as for the 3vze motor, do a search on here...
they are reliable torqy little motors if you treat them right...
and yes, they ARE dependable... my odo with 260K proves that...
Try trail riding a 4runner and you'll see that whoever told you that is wrong too.
THANK YOU!!!! I JUST HAVE LOTS OF PEOPLE PUTTING MY 4RUNNA DOWN AND PLUS IM THE ONLY ONE IN THE CREW WITH A 90 4RUNNER. i GUESS LiKE THEY SAY "NEVER BELIEVE IT UNTIL U SEE IT" RIGHT!! HAVE U GUYS GONE TO TUFF RUBICON WITH 3" BODY LIFT B4 AND DID ANYTHING HAPPENS?
Calm down.
EVERY motor out there has it's common problems. Alot of people have problems with head gaskets, but ALOT more people have never had a problem. I recently burnt a valve in my 3VZE, but that's what happens when you hold it pinned towing a trailer uphill with over 230k miles on the clock.
I'm not into body lifts and I would take it off, but alot of people like them because it's cheap clearance. Put a locker in the back of that thing and you'll shut everybody up who says they don't offroad well.
Flying91
45
Apr 11, 2024 04:39 PM
BeMiceElf
Oct 10, 2015 09:40 PM
