95.5 Tacoma axle options
Old Feb 18, 2009 | 01:54 PM
savagesloth's Avatar
This question probably been asked before so nobody get upset. What different jeep axles are compatible for 95.5 and up Tacoma's front SAS swaps? Whomever knows please be model and year specific. Also would I be able to run my stock transfer case with a jeep axle swap with of course modifying my drive shaft?
Old Feb 18, 2009 | 03:09 PM
crolison's Avatar
Only one I'd run is an older dana44 out of a wagoneer
Old Feb 18, 2009 | 03:26 PM
I was told that too about the wagoneer axles. Would cherokee dana 40 axles work also besides the fact of having to use 5 lug rims up front? Also I forgot to ask what kind of steering box would be needed for a swap with jeep axles, would the older 81-85 Toyota solid axle steering box be compatible? If so what kind of steering linkage would I have to fab up to make this all work?
Old Feb 18, 2009 | 04:10 PM
cubuff4runner's Avatar
Try a search. There is tons of information already out there, and a lot of research needs to be done before hand.
Driver drop waggy axle is going to give you the same width as your rear. Any toyota 4x4 steering box 86-95 will work. A high steer kit should be used..
Old Feb 18, 2009 | 04:21 PM
crolison's Avatar
ditto
Flying91
45
Apr 11, 2024 04:39 PM
polo451
13
Nov 20, 2016 07:49 PM
RobotMoose
Diesel Swaps
Aug 2, 2015 11:00 PM
justdifferentials
Just Differentials
Jul 22, 2015 08:26 PM
msane99
Jul 17, 2015 10:13 AM
