elbow on valve cover?
Old Feb 1, 2009 | 12:57 PM
nomiss05's Avatar
what is the peice that comes up out of the valve cover and is a elbow that bends to the left witha hose coming off it? and how important is it to my truck? and what happens if i broke that? any help?
Old Feb 1, 2009 | 01:20 PM
jason191918's Avatar
Most likely a PCV or vacuum line. Important either way.
Old Feb 1, 2009 | 02:27 PM
herpestes's Avatar
it is most likely from the under side of the air cleaner feeding the front of the valve cover just behind the oil fill cap. part of the PCV system
Old Feb 1, 2009 | 10:41 PM
XtraSlow_XtraCab's Avatar
essentially, the air cleaner is also doubling as an oil breather. the pcv valve is stuck in side the rear center of your valve cover and connects down to the intake somewhere.
Old Feb 1, 2009 | 10:43 PM
algranger's Avatar
pcv valve isin the back, the rubber hose in the front is just a breather you should replace them either way
Old Oct 29, 2009 | 06:25 PM
82blueyota's Avatar
im having a simelar issue i have a breather filter on this port and am tryng to find out if this creates a vaccume leak.see lots of people rumnning just a filter
and lots of people running it to the intake.i am currently running a filter
scratching my head on trynig to put a hose on it to the intake
Old Nov 2, 2009 | 05:45 AM
83's Avatar
83
As stated, if it's the back one it's the PCV. Replace it. If it's the front one, it's the crankcase vent, replace it. If you have a weber carb and there is nowhere on it to attach that front hose, put a filter on it instead so you aren't sucking dirt/water etc. in there.
he's gone
7
Dec 3, 2019 07:08 AM
JNapolitano
Nov 14, 2019 07:46 PM
Sep 4, 2015 09:27 AM
irritech
Jul 27, 2015 05:15 PM
calderp
Jul 27, 2015 09:58 AM
