Power Steering Hose Alternative.
My power steering line has been swelling and leaking fluid. Rather than purchase a hose for $50 + could I go to one of the hydraulic shops around and have them re-crimp a new piece of hose. Does this seem like a good alternative or does this make me sound too cheap?
The folks at the shop should be able to recommend the right type of hose for my application, correct? It would probably be a good idea to add some dye to my power steering (atf) and black light it to see if it leaks anywhere else. What do yall think
ATF already has dye: it's red. I wouldn't add anything to the fluid.
And yes, the hydraulic shop will know what hose to use... and will probably recommend a hose that far exceeds what you need.
An OEM high pressure side ps hose is just a tad more than $50 at the dealer...most start at about $300 and get stupid high from there.
Get one from a junkyard as they are all the same 86-95 on all the Toyota 4x4s.
Low pressure side is just local auto parts hose and some hose clamps.
montanatruck
Feb 26, 2017 07:07 AM
terminator
Jul 27, 2015 07:13 PM
whereAreMyPants
Jul 22, 2015 03:32 AM
jon.r
Jul 11, 2015 03:34 PM
