1988 Yota Fuel Injection Problem?
Old Dec 25, 2008 | 09:53 AM
Sravoff's Avatar
I've got a 1988 toyota 4x4 manual with fuel injection. It ran absolutely great, until I tried to turn it over and it wouldn't start. I was at the time driving to San Francisco and back (ten hours or so round trip). I let it cool down for a few minutes, and it started again. Then it died again and wouldn't start.
A friend of our suggested the ignition module, and after shelling out the $300 I'm at the same place.
I've checked the middle wire on the alternator that comes from the coil, and it sparks. The tail pipe doesn't smell like a whole lot of gas after cranking it over a few times.
I'm thinking fuel injection since everything else seems to be fine. My dad was thinking a fuel injection fuse, but I haven't found anything that looks like that.
Any help would be great.
Thank you in advance,
-Sravoff
Old Dec 25, 2008 | 08:14 PM
DudeBud's Avatar
there are two efi fuses. one is in the cab and one is under the hood in the fuse block. you might try the fuel pump after you check the fuses.http://www.4crawler.com/4x4/CheapTri...shtml#FuelPump
Old Dec 27, 2008 | 10:01 PM
Sravoff's Avatar
Thanks! I'll check them out and get back to you.
Charecter1
Nov 6, 2023 10:08 AM
jbv808
Aug 6, 2021 04:47 PM
mskalmus
May 28, 2017 07:51 AM
karbin
Jul 5, 2015 11:37 PM
